Thread: Different speaker impedances on amp |
| Posted on Sunday, July 13, 2003 - 04:27 pm: |
i need advice on connecting 3 speakers to an amp. i've got a dvc sub (4 ohms per coil 150W RMS) and a pair of rear speakers (4 ohms 120W each). 1) can i use a bridgeable 2 channel amp and run the rear speakers on the separate channels and then bridge those same 2 channels and connect the sub (either in series for 8 ohm load or in parallel for a 2 ohm load)? 2) can i use a bridgeable 4-channel amp in a similar way? run the two rears off 2 channels and bridge the other remaining 2 channels for my sub which will present a different load/impedance. guess my concern is whether or not tri-mode capable amps can be run this way (with different speaker impedances & bridged)?? thanks, kgj |
| Posted on Wednesday, July 16, 2003 - 12:16 pm: |
can anyone help on this?? |
