Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Need help.....which pioneer amp will ...
Author Thread: Need help.....which pioneer amp will do the job
Username: Igor_xxx
I have pioneer ts-w307d2 400watts rms and i have problem with finding the right amp to power it.i dont have a lot of money to spend (200$ max)and i dont want to break the windows.My car audio is all Pioneer and i like to stay that way and get a decent pioneer amp for the money.My favourite for the money is gm-5300t bridgable.what do you guys think?thanks
Username: Kaerfpl
Spencerport, NY
Post Number: 536
You would be able to use that amplifier with your subwoofer but, there are two things that I want to point out first. One, Pioneer amplifiers arn't that great and are usually all overrated and two, if you were going to bridge that amplifier, you would have to wire it in Series (click link for diagram).
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Personally, I think you would be much happier buying this and bridging it: http://www.sonicelectronix.com/item_6527_Hifonics+ZXi+4006.html
If you want to run your subwoofer into a 1ohm load, the closest amp I could find around your subwoofers Specs would be this: http://www.sonicelectronix.com/item_9927_Memphis+16-PR1.500.html
Only issue with this amp is that you may overpower your sub, resulting in a blown VC or something else which is bad. I used to own a pair of Pioneer TS-W301R's and gave them both 50 Watts extra and still worked fine with out any problems. Not really sure if 100 extra watts would kill it or not but if it does, you can always buy two of these: http://www.sonicelectronix.com/item_6808_Pioneer+TS-W251R.html
Username: Igor_xxx
Thanks joe...I'm planning to run this at series at 4ohm and still I am confused how much powerful amp should i buy to make it bump hard but dont blow the subwoofer apart.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4896
well igor i installed those subs (a pair) with a power acoustik a1000db and it bumps pretty nice for the money, plus it costs less than 180 so you can buy it if you want.
That's based on my experience
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Need help.....which pioneer amp will ... [ « Previous ] [ Next » ]
