Thread: New Speakers |
Bronze Member Username: Audiostud
Stillwater,
OK
Post Number: 77 Registered: Oct-06
| Posted on Friday, September 07, 2007 - 12:44 am: |
Should I go with Infinity Kappas or Alpine Type-Rs for 6.5 thanks |
Silver Member Username: Kpa2727
Post Number: 610 Registered: May-07
| Posted on Saturday, September 08, 2007 - 12:29 am: |
ether ones so so kappas prob the best bet if u run them on amp. as far as r's go only reallt good r stuff is thier woofers. i'd stick with r's only if being ran off head unit. plus i also would consider diff speakers. i own infinity reference and theier extreamly clear but can't give u a whole lotta bass. |
Stillwater,
OK
Post Number: 78 Registered: Oct-06
| Posted on Saturday, September 08, 2007 - 03:16 am: |
what other speakers would you recommend in that price range? they're gonna be running off the head unit that only gives 50x4 RMS. I know it doesn't matter but it is an alpine hu. Also I'm getting kappas for the back speakers so I was wondering if matching is good. Or should I go with somethin else entirely? |
Post Number: 613 Registered: May-07
| Posted on Sunday, September 09, 2007 - 01:17 am: |
i got infinity reference up front alpine type - s in back. thier kind of really low budget but they sound fine they way i tuned them and are amed. the big thing is just knowing what u are gonna do. since ur running the hu just stick with the kappas i'm sur u will be more then happy. only other options are componets but ur talkin 4 - 500 for a real decent pair. |
