Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Come on guys i need some help
Author Thread: Come on guys i need some help
Username: Ts0uthern5980
Post Number: 9
i have 2 10' kickers with like 1200rms dual 2.. whats a good amp for them
Username: Th3pwn3r
Post Number:...
Post Number: 4713
List exactly what subs they are and what you're willing to spend on an amplifier.
Post Number: 11
there kicker cvx's,, and like no more than 250 i wwas looking at the boss bl3kd i was wonderind if thats a good one aer just a waiste.. thx
Username: Th3pwn3r
Post Number:...
Post Number: 4743
Boss products are complete trash.I wouldn't even use a Boss fuse block.
Post Number: 13
weell then wat should i use??
Username: Th3pwn3r
Post Number:...
Post Number: 4753
Look into refurbished Kicker amps for that budget.
Post Number: 16
well are those like any good are they gna go out fast and what about if i had like 350
Username: •cam•
Post Number: 652
refurbished kicker is fine. 350's even better.
Post Number: 21
well what one would be the best for me
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 12825
I have a Ed Nine.1 for sale...does 1200rms@1ohms at 12.5volts...$245 shipped
Post Number: 24
not really what im looking for but thanx anyways.. any other suggestions.. like what type of kicker amp i should get if i get refurbished
Username: Mizzle
get hifonics brutus 1200 cant go wrong
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 1107
I would buy Chauncey over the hifonics. Kicker refu are good amp but i would buy Chauncey amp.
Username: Somedonniedude
Post Number: 218
the hifonics brutus wont work with those. He need an amp that will do 1200rms @ 2 ohms. Are these the cvx's? Take a look a the zx1500.1
Post Number: 26
yea they are.. thx for th ehelp
Post Number: 27
do u think i should go with the sx1250.1 r the kx1500.1 after u guys answer this my questiions will be done thx
Post Number: 220
those amps will only put out power @ 1 ohm, you'll need an amp that will put it out @ 2 ohm. The zx1500.1 will do 1500rms+ @ 2 ohms. There are other amps besides kicker, but it depends how much you want to spend, and what you want out of an amp.
Post Number: 222
(just thought of this) what kind of car are you putting this into? Do you have any electrical upgrades yet? 1500w is alot of power for most stock electrical. The zx1000.1 amp will do between 1100-1200watts rms. What im getting at is that if you dont have proper electrical, and dont plan on doing any, youd be better off getting the zx1000.1 imo.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Come on guys i need some help [ « Previous ] [ Next » ]
