Thread: What does a phase shifter do??? |
Bronze Member Username: Khae
Post Number: 67 Registered: May-07
| Posted on Wednesday, September 05, 2007 - 08:06 am: |
any one know what a phase shifter does?? cus my neighbor asked me if i wanted to buy a audiobahn phase shifter for 30 bucks it was brand new..... |
Silver Member Username: Philly306
North carolina
Post Number: 320 Registered: Apr-07
| Posted on Wednesday, September 05, 2007 - 09:05 pm: |
don't. its audiobahn |
Bronze Member Username: Santa_fe
Post Number: 96 Registered: Jul-07
| Posted on Wednesday, September 05, 2007 - 09:43 pm: |
lolz dont base it off that some product are good while other aer VERY shaky....not sure on what it does tho lol |
Silver Member Username: Evoixmr
Post Number: 112 Registered: Aug-07
| Posted on Thursday, September 06, 2007 - 12:35 am: |
It shifts the phase from normal to reverse phase |
Post Number: 113 Registered: Aug-07
| Posted on Thursday, September 06, 2007 - 12:40 am: |
The phase shift switch allows you to select 0 or 180 degrees. The phase shift switch can be used to prevent phase cancellation of low frequencies that are output by the subwoofer. Matching the phase of your subwoofers with the phase of other speakers in your system ensures bass response does not suffer due to phase cancellation. |
Bronze Member Username: Sqcheap
Grand rapids,
Michigan
Usa
Post Number: 91 Registered: Jul-07
| Posted on Thursday, September 06, 2007 - 01:42 am: |
It could make it sound better depending on some things like the response of your system and what enclosure you are using on your subs. |
Post Number: 68 Registered: May-07
| Posted on Thursday, September 06, 2007 - 05:27 am: |
oh imma be using a kicker l7 15 inch with a kicker kx 1200.1 amp n a ported box |
North carolina
Post Number: 321 Registered: Apr-07
| Posted on Thursday, September 06, 2007 - 08:57 am: |
"lolz dont base it off that some product are good while other aer VERY shaky....not sure on what it does tho lol" with company like audiobahn making crappy subs, speakers, amps, and pretty much everything else, what are the chances of them making good phase shifters common sense |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 4699 Registered: Jul-06
| Posted on Thursday, September 06, 2007 - 09:59 am: |
Like I said Khae,if you want your money go ahead and buy that.You don't need it so...why waste your hard earned dollar? |
Silver Member Username: Wojopro
Summerville,
SC
Post Number: 353 Registered: Nov-04
| Posted on Thursday, September 06, 2007 - 02:07 pm: |
My head unit has it built in. |
Post Number:...
Post Number: 4737 Registered: Jul-06
| Posted on Thursday, September 06, 2007 - 03:11 pm: |
"Like I said Khae,if you want your money go ahead and buy that.You don't need it so...why waste your hard earned dollar?" I meant to say "if you want to waste your money go ahead and buy that." |
Gold Member Username: Insearchofbass
Post Number: 6383 Registered: Jun-04
| Posted on Sunday, September 09, 2007 - 03:18 pm: |
It could add spl to your score .....my bro has a phase shift on his headunit and it increased our spl. (We tested with our spl meter) |
