Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Need help with power problems with amp
Author Thread: Need help with power problems with amp
Username: Tril
Hey guys, i installed a 700 watt amp in my car it worked fine for a few weeks but now when i turn the a/c on or roll down the windws it starts to make a funny noise as if the cd was skipping or something like that can anyone help please
Username: Somedonniedude
Post Number: 179
Thats clipping. You can fry your amp from that. Sounds like your car electrical cant keep up with your car and system or maybe a bad connection or ground somewhere. What kind of car do you drive and what equipment do you have?
Username: Sqcheap
Grand rapids, Michigan
Usa
Post Number: 90
Check all your grounds first.
Username: Th3pwn3r
Post Number:...
Post Number: 4704
A "700" watt amp really shouldn't be so demanding of current.I don't think that's whats going on...I think you may have a short in your wiring somewhere.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Need help with power problems with amp [ « Previous ] [ Next » ]
