Thread: Quick fuse question |
New member Username: Aqua_acura
Post Number: 10 Registered: Aug-07
| Posted on Tuesday, September 04, 2007 - 04:27 pm: |
Alright, I don't deal with fuses much, so thought I should ask before I do something stupid. If my amp recommends a 60 amp fuse for the power cable, is it okay if I use a higher fuse? I have the choice of buying either a 60 amp agu fuse or a 150amp anl fuse (wire kit) and wasn't sure if I can use the 150 or not(anl fuses are better, so I'd like to go with that). Thanks. |
Bronze Member Username: Moz
Post Number: 14 Registered: Sep-07
| Posted on Wednesday, September 12, 2007 - 01:24 pm: |
it just depends on the wire that your running so i would do what the kit recommends |
New member Username: Brent113
Post Number: 7 Registered: Sep-07
| Posted on Thursday, September 13, 2007 - 07:17 pm: |
Usually you should use a fuse with an amperage rating of 80% of the wire's. |
Bronze Member Username: Cblaze
Tn
Us
Post Number: 40 Registered: Sep-07
| Posted on Friday, September 14, 2007 - 12:36 am: |
i wouldnt go to high above the amps fuse rating,i mean the fuse is there for a reason ya know. |
New member Username: Zxhoon
| Posted on Sunday, September 23, 2007 - 03:23 am: |
if the amp has fuses built in (most do) the fuse you put on the cable at the battery end is to protect the cable only, so if the cable can handle 150 amps, fuse it at 150 amps... fuse needs to be the weakest link in the system... |
