Thread: Bxi1606D |
Bronze Member Username: Homeboi88
Lexington ,
Kentucky
United states
Post Number: 49 Registered: Apr-07
| Posted on Friday, August 31, 2007 - 08:34 am: |
i kno the hifonics amps r overrated but they are pretty good amps arent they? |
Gold Member Username: Mixmastaspig
Canada,
Post Number: 1065 Registered: Sep-05
| Posted on Friday, August 31, 2007 - 11:18 am: |
A decent budget amp, yes. |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1276 Registered: Mar-06
| Posted on Friday, August 31, 2007 - 01:37 pm: |
What kind of budget do you have? You are looking for around 1500 @ 1 ohm correct? Kevin |
New member Username: D_buls
Des Moines,
IA
Post Number: 1 Registered: Sep-07
| Posted on Saturday, September 08, 2007 - 05:47 pm: |
i had one hooked up to 2 12" cvrs and blew them after a month, I hooked up two 12 cvx's and the inside of the amp melted after about an hour. |
Gold Member Username: Loudon
Post Number: 1697 Registered: Jun-04
| Posted on Saturday, September 08, 2007 - 06:20 pm: |
then ur doing something wrong dan |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 290 Registered: Jul-07
| Posted on Sunday, September 09, 2007 - 01:40 am: |
hey i think hifonics is awsome about to buy another amp from them to power my cvrs 600 watts a piece anyone want to buy a hifonics 600.1 |
Silver Member Username: Wojopro
Summerville,
SC
Post Number: 357 Registered: Nov-04
| Posted on Sunday, September 09, 2007 - 11:03 am: |
Couldn't agree more Mike. |
Des Moines,
IA
Post Number: 2 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 09:50 pm: |
I had two dual voice coil 4 ohm cvx's wired down to one ohm the exact same way i had the cvr's. I turned the gain up and the protect light came on after about an hour. i took the amp apart and one of the little diode things inside had exploded over the circuit board and the plastic around the power wire inside had shrunk because of how hot it got. great BUDGET amp for a couple months but but wont go with it again. Should be fine as long as you dont actually try to get 1600 RMS from it. |
Silver Member Username: Somedonniedude
Post Number: 209 Registered: May-07
| Posted on Monday, September 10, 2007 - 12:38 am: |
Hey ben did you figure out what was wrong with your system? |
Louisville,
Ky
Post Number: 294 Registered: Jul-07
| Posted on Tuesday, September 11, 2007 - 12:37 pm: |
yeah i figured it out and i felt so stupid for ridding arround that whole weekend thinking my subs were blown when the only thing that happened was the RCA cable came unpluged from the HU |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 12819 Registered: Jul-05
| Posted on Tuesday, September 11, 2007 - 02:02 pm: |
"I turned the gain up" Did you set the gain correctly or just turn it up all the way?? |
Des Moines,
IA
Post Number: 3 Registered: Sep-07
| Posted on Tuesday, September 11, 2007 - 06:12 pm: |
i turned it up a lot higher than what it was, but i dont see how that would make it break? I had to turn it up that far to push the cvx's good |
Huntsville,
Alabama
U.S.
Post Number: 12823 Registered: Jul-05
| Posted on Wednesday, September 12, 2007 - 01:08 am: |
The gain is not a volume knob.. "but i dont see how that would make it break" Thats exactly why it broke "I had to turn it up that far to push the cvx's good" If you set ur gains correct you will get the full power out of your amp with out having to turn it all the way up... Please learn what everything means and does in your car audio system...Trust me you will save alot of money in the long run |
