Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Soundstream
Author Thread: Soundstream
Username: Homeboi88
Lexington , Kentucky
United states
Post Number: 47
do those soundstream 2000d amps put out true power? hit me bak
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 12727
With a proper electrical system you should see close to if not rated power
Username: Homeboi88
United states
Post Number: 48
rite dats a bet so would a battery cap be good?
Huntsville, Alabama
U.S.
Post Number: 12729
"battery cap be good?"
Depends on if you have everything else..
Username: Rovin
4 10 Pioneer...
Post Number: 12093
i own a SS 2000d - works quite well ....
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4880
I think is the greatest budget/quality amp around these days.
Username: Rovin
4 10 Pioneer...
Post Number: 12125
i know alot of ecoustics members dont like POWER ACOUSTIK but their 3000d model has a very similar board to the SS & quite alot of ppl use the PA amps in my country with good results .....
Username: Crossfired
Post Number: 18
It will do its rated power and a little more. It will also cause a fire(like any high power amp) if you do a monkey install.
Username: Theweasel
2 12 FI SSD, Colorado
U.S. of A
Post Number: 1060
just what exactly is a monkey install?
Username: Th3pwn3r
Post Number:...
Post Number: 4701
"i know alot of ecoustics members dont like POWER ACOUSTIK but their 3000d model has a very similar board to the SS & quite alot of ppl use the PA amps in my country with good results ....."
Why do you think that is Rovin?Do you know who owns Soundstream now?Soundstream is over-seas made crap now.They have a couple good amps but most of their products are crap.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4895
sorry rob but i agree with rovin, i've messed with power acoustik a DB mono line and it does the job quite well for the money.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Soundstream [ « Previous ] [ Next » ]
