Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Instead of setting gain should it mat...
Author Thread: Instead of setting gain should it match the volt?
Username: Panamanian
Panama city
Panama
Post Number: 225
Instead of configuring the gain by playing the song very loud without distortion, shouldn't it just match the same volt between the HeadUnit and the Amplifier?
Say your HeadUnit output is 4volts, your amplifier must match that 4volts and that's it?
Or YOU STILL MUST play a loud music and increase or reduce the gain level?
Username: Jesse59672
OKLAHOMA
Post Number: 557
its called an amplifier for a reason. if you were to set it to four volts i don't think your sub(s) would get very loud. it amplifies the signal given by the head unit.
this might help you more.
http://subwoofertools.com/forum/setgain.asp
Username: Nd4spd18
Southeast PA
Post Number: 3205
^^^^^ Use that link, the only way to correctly set the gain.
And check out the interactive tutorial from JL its very helpful. Just remember to turn off EQ, loudness, and all other functions on the HU or the voltage reading will be wildly wrong.
Username: Moey_g
Sydney
Australia
Post Number: 146
Actually the amp IS suppose to match the voltage from the HU. So you should set the amp to 4 volts...
Username: Wojopro
Summerville, SC
Post Number: 356
Use the link Jesse provided
Username: N2audio
Lawrence, Ks
Post Number: 1386
the problem with just setting the gain to the voltage specified by the HU is that the HU's actual rms voltage is nowhere near it's specified output.<br>
The sinewave gain setting method is a very good reference setting, but if you listen to music and not sinewaves it shouldn't be a problem to increase the gain a good 10-20% from the reference point.
IMO - use a DMM initially, your ears to fine tune.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Instead of setting gain should it mat... [ « Previous ] [ Next » ]
