Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Need help locating alternator on 93 v...
Author Thread: Need help locating alternator on 93 volvo 240
Username: Vjking127
How do you locate the + and - of the alternator in the Volvo? I want to connect these 3 wires to these places: - Negative from alternator to chassis.
- Positive from alternator to battery.
- Negative from battery to chassis.
Username: Th3pwn3r
Post Number:...
Post Number: 4389
You can use a test light to find the positive output on the alternator and just tap the negative around the alt mounts from the test light to find a ground but you should use a digital multi meter to find the best possible contact area.You can also trace the wire hooked up to the battery positive back to the rear of the alternator.
Username: Drwang
Santa cruz, Ca
Post Number: 60
but where is the alternator in a 1993 volvo 240? and if i don't have a digital multi meter, can i use something else?
Username: Th3pwn3r
Post Number:...
Post Number: 4437
Take a look at where your belts are run.Your alternator's pulley is driven by a belt so it shouldn't be too hard to spot.Like I said up above you can trace the power wire from your batt back to your alternator.If you don't have a multi meter(they cost 20 bucks) you can use a test light but it's not as good for testing certain things(they cost about 5 bucks).
Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Need help locating alternator on 93 v... [ « Previous ] [ Next » ]
