Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Clean sound
Author Thread: Clean sound
Username: Kennyman
Post Number: 13
is there something that I can get that will give me a good clean signal going into my amps?
Username: Glasswolf
NorthWest, Michigan
Post Number: 3079
from what? a head unit with pre-amp outputs?
sure, it's called a line-driver.
www.audiocontrol.com makes one. a very nice one.
Username: Dread07
Oshkosh, Wisconsin
Post Number: 10
Line driver is mounted in rear of car by amps? w/ rca connections or what
Username: Glasswolf
NorthWest, Michigan
Post Number: 3119
depends on the line driver.
many mount behind the head unit, and connect to a +12V source for power, then you run the head unit RCA lines to the little box, and out of the box to the amps.
the little device has a screw adjuster for setting the oyutput voltage similar to the gains on an amp usually.
Others are built into devices like audiocontrol's EQs, Premaps, and Signal Processors. then you just go through the signal processor and set output voltage on the device.
its all integrated
Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Clean sound [ « Previous ] [ Next » ]
