Home > Message Board > Car Audio > Disc Changers > Fujitsu Ten 86270-14051
Author Thread: Fujitsu Ten 86270-14051
I have a Fujitsu Ten out of a Toyota and would like to know what year Toyota it came out of and if there is a cable available so that I can install it in a 1990 Tercel. It is a two unit system with a CD unit separate from a AM/FM/Radio/Cassette unit. It has the Model Number SD-1310TLIA on the label and the number 86270-14051 also on the label. It has a fourteen pin connector on the rear of the am/fm cassette unit. Any help????
Relevant Product Info
Hi I have a Toyota Yaris 2003 VVTi 1.0 T2 with the standard audio system of a radio and cassette. It has the ability to plug in a cd changer and I have a Sony CDX-T69 but do not know if this changer will fit. I do not know what sockets are on the standard radio.
Any one have any ideas thanks.
Mike
I have a Fujitsu Ten Radio/Cassette that doen't "hold" the time or the preset stations I put in. I set the time and put new Stations in; when I turn off the car ignition and leave it for a while the time and stations are lost next time I turn it on. Any ideas? Worth Fixing?
Hi, i have 86120-28390 fujitsu ten 135000-1080A101 out of toyota, 16023 voice navigation, im selling it, please feel free to e-mail me at g_liang_17@yahoo.com, don't forget to include your full contact details, thanks =)
Hello,
I have a Fujitsu Ten 5170, in dash 6 disk changer, in a 2000 Isuzu Rodeo, that I'm having problems with, can anyone help me with this?
Thanx in advance,
Ron V.
Chrisw
hi i have a fujitsu ten 86120-35140 tv/sat nav, fm radio. Its out of a toyota hilux surf 1996 and i was wanting some info on it.
Email me at chris.junkie@gmail.com
Cheers
Chris
Fujitsu Ten radio from a Toyota Van, Mod 86120-14371 (CE-423TL2)
Display shows 'co 7'. Can someone give me an idea of what may be wrong?
Username: Nra
Colombo, Western
Sri Lanka
I have been presented with a Fujitsu Ten AM/FM Car Radio made in Malaysia by a person living in Australia. When I connect it before fitting to the car I get a message "SEC" on the the display. The Code he gave me does not respond. How do I lay my hands on the security code? I do have the Serial Number of the set.
Username: Bush_pylot
I have a fujitsu ten car stereo in my 1994 Mazda mx6 LS model number 121000-1400d101. I replaced the car battery and lost the code in the radio. I aquired the code from the person I bought the car from and tried it 3 times (entered with wrong procedure). Radio is now locked out. I was informed there is a reset button on back of the radio, but cannot locate it. Without removing the radio and further dismantling the dash, how do I locate this button to reset the radio?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Disc Changers > Fujitsu Ten 86270-14051 [ « Previous ] [ Next » ]
