Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Grounds
Author Thread: Grounds
Username: Somedonniedude
Post Number: 118
Currently i have a 600 watt amp and a 1 farad cap sharing the same ground which is on my wheel well in my trunk. I was thinking about adding another 300 watt amp. Should i make a new ground in my trunk or will just the one be ok? I was thinking about making another ground on the opposite wheel well and then connect them all into a distro block. Just looking for a few opinions or better ideas.
Username: Aj1218
Post Number: 54
easiest way is just to make another ground hole. That way you can make the ground wires as short as possible. Using the same ground is not necessary
Username: Killswitchjd
Post Number: 659
ones fine
Post Number: 124
should I get like 2 ga ground cuz im gonna prolly install a sec run a 4 ga, if i need it. I just bought a digital distro block for a sec amp and i can just watch my voltage closley first on it.
Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Grounds [ « Previous ] [ Next » ]
