Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > HELP! Do I need better speakers?
Author Thread: HELP! Do I need better speakers?
Username: Rikki
I have a 2002 Dodge Durango with the infinity sound system (supposedly good) and recently replaced the CD receiver with at Sony Xplod (CDXGT610U) one. My problem is that back seat passengers are having trouble hearing music while it is fine in the front. I have tried adjusting the balance but it doesn't make a whole lot of difference. I am thinking of replacing the rear speakers. Is this necessary? What speakers should I choose considering I do not want to spend too much money?
Username: Rikki
Upon doing some more research I have discovered that the CD receiver I removed had about 180W more power than the one I put in. Would I be able to put all of my stock speakers through an amp and would this solve my problem? If I should then which amp should I buy?
A pic is worth
1000 posts!!
Post Number: 9278
What you should've done is take that sony back lol. What made you replace your HU with a grossly underpowered replacement? Like the color?
Research, educate, execute. That order.
TGIF.
Cheers!
Username: Rikki
Well the colour was appealing but it was the fact that it read mp3 CDs that was appealing, and I didn't know that much about it, so I figured as long as it was compatible, which I was told it was, then everything would be fine. Apparently I should have done more research. What can I do now that I have it though? I'd really rather not go back to the old one or replace it again.
A pic is worth
1000 posts!!
Post Number: 9306
You're gonna need more power to your rears, meaning an amp to make up for what power you lost switching HU's. Either way you're gonna need to spend more $$.
Username: Rikki
ok fair enough. How powerful an amp would I need, and what amp would you recommend?
Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > HELP! Do I need better speakers? [ « Previous ] [ Next » ]
