Thread: Please help me choose! =) |
New member Username: Jamesmington
Post Number: 2 Registered: Jul-07
| Posted on Wednesday, August 15, 2007 - 03:52 pm: |
I drive a 2003 Volvo S40, and after blowing out my speakers and doing a lot of research I've narrowed down my selection of new speakers. The problem is I'm not sure, which i should go with. So any help would be awesome! I've decided on 5 1/4" component speakers in the front: Alpine SPR-13S JL Audio VR525-CSi and I plan on getting 6 1/2 speakers for the rear: Alpine SPS-17C2 Polk Audio db650 if anyone could help me choose between the 2 in each category, I'd greatly appreciate it. I also plan on getting subs and I was told that I wouldn't need rear speakers if I got subs, does anyone have any feedback on this? |
New member Username: Blitzd55
Post Number: 6 Registered: Aug-07
| Posted on Wednesday, August 15, 2007 - 08:45 pm: |
this is way off the topic of your post but i work with a guy who is a good friend of mine named Kiet Nguyen ahhh hahahaha thought that was a little coincidental just had to mention that |
Gold Member Username: Jkidder
Spring hill,
Florida
Usa
Post Number: 1633 Registered: Nov-05
| Posted on Monday, August 20, 2007 - 12:21 am: |
x2^ HAHAHAHAHAHHAHAHAHHAHAHAHAHAHAH anyway, are you open to other options? like used? not mainstream? what amp would you use for your components? whats budget? and is it possible to fit a 6 1/2 up front. it's really limiting if you can only fit 5.25's. but look at brands such as cdt, focal, image dynamics (not sure if they make 5.25's), mb quart. it all depends on your budget and amp though. |
Spring hill,
Florida
Usa
Post Number: 1634 Registered: Nov-05
| Posted on Monday, August 20, 2007 - 12:22 am: |
but out of what you picked i'd go with JL's up front and justin ogle has those 6 1/2 type s components on here for real cheap. like 50 shipped or something. so those. |
Silver Member Username: Warlok
Orlando,
FL
Post Number: 379 Registered: Dec-05
| Posted on Monday, August 20, 2007 - 12:51 am: |
^^ I 2nd the JL's in front |
Post Number: 3 Registered: Jul-07
| Posted on Monday, August 27, 2007 - 08:57 pm: |
"anyway, are you open to other options? like used? not mainstream? what amp would you use for your components? whats budget? and is it possible to fit a 6 1/2 up front. it's really limiting if you can only fit 5.25's. but look at brands such as cdt, focal, image dynamics (not sure if they make 5.25's), mb quart. it all depends on your budget and amp though." sorry for the slow response, ive been busy on a trip. i am definitely open to other options...used is ok, but it sounds like a gamble to me because there's no way to tell of its quality online, but its an option. im not sure on which amp to go with. but yea, only 5.25's go in the front =/ ive been getting advice from this guy on crutchfield. he said that my best bet would be to go with: Polk db5250 (front) Polk db6500 (rear) Pioneer 3900 (headunit) and an 80x4 amp. which is undecided. i checked out the polks, and its quality is great with nice highs, but it lacks in the midbass range. i may plan on getting an Alpine Type-R 12" kicker but no time soon. as for my budget, im just trying to stay on $1000 with everything installed...and with that is the reason why im a little iffy with the JL's in the front cuz of its price, but im sure its quality is phenomenal, eh? but idk about mixing brands and what not in a car. any suggestions? |
IA,
DP
RD
Post Number: 1801 Registered: Nov-05
| Posted on Tuesday, August 28, 2007 - 03:42 pm: |
do you have aim kien? hit me up if u do - jk32sho i'll help you out i just dont like posting and typing too much on this forum. |
Bronze Member Username: Paarlberg
Post Number: 32 Registered: Aug-07
| Posted on Wednesday, August 29, 2007 - 09:30 am: |
I am getting elemental designs for my car. They have great speakers for a great price. www.edesignaudio.com I just ordered a replacement for my blown 9 year old sub. It is a 10" dual 2 ohm for $90 shipped. They have a very good following and excellent customer service from what I have read and seen so far. They have a set of components starting at $95 after forum member discount. (not this forum, but theirs) |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1586 Registered: Jan-06
| Posted on Wednesday, August 29, 2007 - 01:43 pm: |
edesign is a love hate company and products. i've used their products and found it good for the price but lacking when compared to stuff they say it should be comparable to. There is a little more hype to them than i like. Only product i use is their edead since its cheap and use it on the floor as thats all its about good for. I use better quality products for trunk lid and doors. |
Post Number: 33 Registered: Aug-07
| Posted on Wednesday, August 29, 2007 - 03:27 pm: |
I agree they are a love/hate company.. Most are IMO (sony, kenwood, alpine, etc..). I know they are very cost effective and their products run along the lines of the CDT CL and HD series (from what I understand). I guess that comes from the joint development they had with CDT a few years ago. Which I understand are a good bang for the buck as well.. A lot of the people on their forum use a mix of CDT and eD products. In away, the eD users are kind of anti big name brand.. CDT would also fall into that non name crowd I believe. Nothing against CDT, I haven't heard them or the eD products. I just wanted to throw that option out there as well. |
Post Number: 4 Registered: Jul-07
| Posted on Thursday, August 30, 2007 - 01:27 am: |
sup guys, let me update you on my situation and hopefully I can get some nice feedback/opinions on my selection. This looks like my final decision: Headunit: Pioneer 3900MP Front Component: CDT Audio EuroFrame EF-51 http://audio-n-more.com/thestore/prods/EF-51.html 2 Channel Amp: NSX NA 2120x (2 x 120W @ 4 Ohms) 2x10" Subs: AA Assassin D4 http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=161 Sub Amp: 800.1 RD Audio http://www.rdaudio.net/amps/800.php Konfused Distribution Block: http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12 JL RCA wires 0 and 4 gauge wires from here: http://www.knukonceptz.com/productMaster.cfm?Category=Power%20Wire im a little iffy on the Assassin subs and the RD amp, any thoughts? did i miss anything? thanks! oh yea, major thanks to JK for helping me out all afternoon |
Concord
Post Number: 1587 Registered: Jan-06
| Posted on Friday, August 31, 2007 - 02:38 am: |
email me if you are interested in CDT. If you can go for the HD series. But if not EF is good just not at that price since you are getting last year model parts. |
IA,
DP
RD
Post Number: 1856 Registered: Nov-05
| Posted on Monday, September 03, 2007 - 07:56 pm: |
u'll get more feedback in the subwoofer section |
