Thread: Bass cuts in and out |
Silver Member Username: Holt_champ
Htown,
MI
Post Number: 847 Registered: Oct-06
| Posted on Wednesday, August 15, 2007 - 06:19 am: |
i have a kx2500.1 and 2 fi q's in my car for about a month...all of a sudden my bass cuts out today and then comes back on and my amp goes into protect mode. it seems to only happen when the music is up and the subs are pounding really hard. it sometimes cuts out for like a minute or so and then comes back on pounding again. i checked all my grounds and cant find what the problem is. it seems really wierd that it started happenin for the first time in a month. |
Bronze Member Username: Mark872
Post Number: 43 Registered: Jul-07
| Posted on Wednesday, August 22, 2007 - 12:23 pm: |
Seems like just some wires are touching somewhere...thats usually the case if it just started doing it all of a sudden and only does it when u have ur music up loud |
Silver Member Username: Spivey17323
Dunellen,
New jersey
United states
Post Number: 323 Registered: Jun-07
| Posted on Wednesday, August 22, 2007 - 01:08 pm: |
check your ground wire and your fuse... i know the same type of sh*t was happening to me and that was the problem. good luck |
Htown,
MI
Post Number: 855 Registered: Oct-06
| Posted on Thursday, August 23, 2007 - 05:59 am: |
i thkn my power wire was coming out of the amp. i just pulled it out all the way for now because it kept hitting the ground and causing a spark. |
Htown,
MI
Post Number: 857 Registered: Oct-06
| Posted on Saturday, August 25, 2007 - 08:36 pm: |
well thats not the problem. do u think it has to anything to do with my amp? |
Silver Member Username: Jesse59672
OKLAHOMA
Post Number: 540 Registered: Feb-07
| Posted on Saturday, August 25, 2007 - 11:04 pm: |
what ohm load are you running the q's at? also are your gains set correctly? make sure all of your grounds are still secure. |
Htown,
MI
Post Number: 858 Registered: Oct-06
| Posted on Sunday, August 26, 2007 - 07:49 am: |
im running them at a 2ohm load. they are dual vc. and my gains are set correctly. i havent changed them since i hooked up the amp. i will check the grounds one more time. i also hear like a poppin sound when they cut out. |
Htown,
MI
Post Number: 859 Registered: Oct-06
| Posted on Sunday, August 26, 2007 - 11:26 pm: |
anyone else have a suggestion or have this happen to them? |
Silver Member Username: Moey_g
Sydney Australia
Post Number: 149 Registered: Oct-06
| Posted on Sunday, September 09, 2007 - 06:41 am: |
So the subs are dual 2 ohms? |
Sydney Australia
Post Number: 150 Registered: Oct-06
| Posted on Sunday, September 09, 2007 - 06:45 am: |
They would have to be dual 2ohms to get a final impedance of 2 ohms... Just making sure your running them at 2 ohms since the kx2500.1 is not stable at 1 ohm... |
Bronze Member Username: Khae
Post Number: 69 Registered: May-07
| Posted on Sunday, September 09, 2007 - 06:53 am: |
it could be your wireing connections... same thing happen to me n my kickers using a kx 1200.1 to power a 15 inch l7 it kept on goin into protection mode as well on and offf when it gets turned up high..... n i checked all the wires it was my ground... had a bad ground spot.. so i replaced it to a better place and it stoped doing that.... but it did that once so far it was cus i didnt clean the part of where i grounded it better like scrap it to bare metal where the ground is goin to be... |
New member Username: Ghavens1981
Lexington ,
Ky
United states
Post Number: 1 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 01:33 pm: |
need help i have 2 12 inch mtx 7500s and a 1000 watt distinct audio amp the subs seem to sometimes hit harder then at other times |
Lexington ,
Ky
United states
Post Number: 2 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 08:44 pm: |
cant get the low bass outta my subs i know they are capable of |
Sydney Australia
Post Number: 151 Registered: Oct-06
| Posted on Wednesday, September 12, 2007 - 07:05 am: |
You should start a new thread greg. |
Silver Member Username: Killswitchjd
Post Number: 668 Registered: Apr-06
| Posted on Thursday, September 13, 2007 - 12:27 pm: |
i think ur clipping your amp |
Bronze Member Username: Moz
Post Number: 24 Registered: Sep-07
| Posted on Thursday, September 13, 2007 - 12:37 pm: |
i think its a lack of power |
