Thread: What box should i get? |
Bronze Member Username: Slicknick
Grove,
Oklahoma
U.S.
Post Number: 15 Registered: Jul-07
| Posted on Tuesday, August 07, 2007 - 01:53 pm: |
i'm planning on getting 2 alpine type r's, i listen to mosly rap/rock and want to know what would be the best box to put these subs in |
Silver Member Username: Explictx
Glen Burnie,
Maryland
Post Number: 298 Registered: Mar-07
| Posted on Tuesday, August 07, 2007 - 08:58 pm: |
If you mean out of sealed and ported, i'd say go ported. |
Bronze Member Username: Thed42
Post Number: 69 Registered: Jun-06
| Posted on Wednesday, August 08, 2007 - 08:38 am: |
I'd say sealed. |
Grove,
Oklahoma
U.S.
Post Number: 16 Registered: Jul-07
| Posted on Thursday, August 09, 2007 - 03:02 pm: |
ok, why sealed? |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 3150 Registered: Jul-06
| Posted on Thursday, August 09, 2007 - 04:28 pm: |
Ported. Sealed is almost never the best choice for subs........ If you want more SQ and/or deeper bass tune the box lower. For more loudness, tune it higher. |
New member Username: Hhs_kid
Post Number: 9 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 11:36 am: |
In my experience, a ported box will be only a little bit more louder than a sealed box but will deff. put out a lot more deep bass which most people want. I have two Kicker 12" CVRs in a sealed box with 1.5 ft^3 per chamber and it hits really hard and takes your breath away. Don't get me wrong, I have really good deep bass but my friend who has the exact subs in a ported box with the same power going to them will play lots lower than mine but on a db meter the difference is only like 3-5 db. Crucial for comps but not really noticable for daily driving. Ported boxes need to be built perfect too and are bigger than sealed. If you want to get as loud as possible for those subs, get ported if you can. That will squeeze every db out of them and will make you say "Damn, I can't breathe!" Should anyways with correct power going to them. I should add that I only have a sealed box because one of my friends gave it to me and why not use something that's free? |
Northwest PA
Post Number: 3525 Registered: Jul-06
| Posted on Tuesday, October 23, 2007 - 05:38 pm: |
Ported with play as low as you want, as will be louder. All depends how you tune it. And 3-5 db is very noticeable. |
