Home > Message Board > Car Audio > Multimedia Systems > Jensen VM9312 - XM will not work
Author Thread: Jensen VM9312 - XM will not work
Username: Tjf
I just had the Jensen VM9312 installed with the xm radio. I had an xmd1000 from a previous xm unit and used the JXMC cables with it. now i am only getting channel 120 and have called xm to resend the signal numerous times with the same results. Any help appreciated thank you all.
Relevant Product Info
Username: Cartoyztxk
Texarkana, Texas
Usa...baby
need a later model xmd1000...just had the same crap
Username: Griz_bear2001
Missoula, MT
Anyone have a Sirius hookedup? What cable did you use?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Multimedia Systems > Jensen VM9312 - XM will not work [ « Previous ] [ Next » ]
