Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Rainbow SLX 265 Deluxe versus CSX 265
Author Thread: Rainbow SLX 265 Deluxe versus CSX 265
Username: Jjohan35
Post Number: 30
Hi folks,
What's the difference and which is 'better'? I can't afford anything higher among the Rainbows, but these two sets are $20 difference. And how do they sound if I have the crossover set around 75Hz?
Secondly my amp runs 75 RMS per channel. Will this be enough to feed either Rainbows set? Thanks!
Username: Adddisorder
West palm, Florida
Post Number: 4890
i dont know the exact difference between those two sets, if i remember correctly the mid is slightly different and they use a different tweeter, but dont quote me on that.
also 75rms each isnt much, i give my slc's 150 each. i wouldnt upgrade the amp until you listen to them though it might be good enough for you.
Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Rainbow SLX 265 Deluxe versus CSX 265 [ « Previous ] [ Next » ]
