Home > Message Board > Car Audio > Navigation Systems > Ford F-150 Factory Navigation
Author Thread: Ford F-150 Factory Navigation
Username: Esim1983
New Iberia, Louisiana
U.S.
I recently installed a factory navigation sytem and do not know how to get the DVD player to work!! Also if I install a camera in the rear of my truck where would I connect the wires to the unit and where would I install the camera? Any help would be much appreciated. Also if you know of any other information on this device that is available please do tell. I am not the most audio intelligent person, this device is totaly new to me and did not come with manuel!! Thank you, Elliot
Relevant Product Info
Username: Wmckay
Fayetteville, NC
US
Hello sir:
The Ford Nav Radio does not have a DVD player, there is a slot behind the screen where you install the nav DVD. To access this slot, you must go to the menu -- also, you cannot install a backup camera through this radio -- wal mart sells a backup camera kit real cheap and it's easy to install. If you need a nav manual, I will send you one by email. My email is; wmckay@nc.rr.com
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Navigation Systems > Ford F-150 Factory Navigation [ « Previous ] [ Next » ]
