Thread: Too little wattage for speakers? |
New member Username: Snookumsthacat
Cincinnati,
Ohio
Post Number: 1 Registered: Jul-07
| Posted on Monday, July 16, 2007 - 07:26 pm: |
I have a power accoustic amplifier that rates: 40 x 4 @ 4 ohms 50 x 4 @ 2 ohms I was trying to find some 3.5" speakers to use with this amplifier for my headrest speakers in my miata. I ended up finding some audiobahn AS31V speakers that are rated: 60 watts rms @ 4 ohms 120 watts max @ 4 ohms I wasn't sure if i should get these or not. I didnt know if the amplifier would damage them or if it would just be poor sound quality because of the differences in rms power ratings for them. Does anyone have any ideas for 3.5" speakers to go with this particular amplifier? Or would these speakers be ok for this amplifier? Thanks! |
Silver Member Username: Warlok
Orlando,
FL
Post Number: 349 Registered: Dec-05
| Posted on Monday, July 16, 2007 - 09:06 pm: |
The speakers and amp will be fine together. Dont expect peak performance, but there just 3.5's, so Im sure you will live. But you can run speakers under rated RMS, it wont hurt them. Just dont try to run a high power sub off of it (lol) and you will be fine. If your woried about power, try bridging to 4 ohms, or running them at 2 ohms, but make sure your amp can handle that configureation. But IMO , you should be fine as is. Anyone else care to 2nd that ? |
Bronze Member Username: Circa09skater
Post Number: 29 Registered: Jun-07
| Posted on Tuesday, July 17, 2007 - 01:12 am: |
2nd |
Silver Member Username: Believe
Illinois
Post Number: 194 Registered: Jun-05
| Posted on Tuesday, July 17, 2007 - 07:27 am: |
theres not enough power with that amp to get any beefy midrange out of the 3.5inch speakers the speakers will sound too bright and youll clip the amp trying to get any dynamics out of the cone |
Silver Member Username: Riebread77
Post Number: 727 Registered: Jun-05
| Posted on Wednesday, August 01, 2007 - 01:33 am: |
infinity 3.5" i believe are 50 or 55 watts rms or so |
Cincinnati,
Ohio
Post Number: 4 Registered: Jul-07
| Posted on Thursday, August 02, 2007 - 12:10 am: |
No, the infinities are what i wanted but they were a big dissapointment the reference series are 25 rms @ 4 ohms and the kappas are 35 rms @ 2 ohms. I just cant beleive there aren't any good 3.5" speakers for this amp to match with. |
