Thread: New Speakers....Do I need new Head Unit |
New member Username: No_idea
Post Number: 2 Registered: Jul-07
| Posted on Tuesday, July 10, 2007 - 08:29 am: |
I currently have a 98 Jeep Grand Cherokee with all stock audio equipment. My speakers are not very loud and they are starting to get scratchy so I was thinking about getting new Speakers. I was looking at the Pioneer model# TS-A1682R. The guy at best buy said if I want them to make a difference I need to buy a new head unit. Can anyone give me suggestions on if I really need to do this |
Gold Member Username: Delsole
Post Number: 1315 Registered: Feb-05
| Posted on Wednesday, July 11, 2007 - 02:00 am: |
well you will hear a difference with after market speakers no matter what head unit you have but i personaly would get another HU, because you will hear more off a difference, but to answer your question you will hear a difference even with a stock HU so tell the best buy guy that he dont know what hes talkin bout. and for you, stay on the forum for a while then buy somthing better from somwere else. but it also depends on wether you buy sh*t or good sh*t. |
New member Username: Jjohan35
Post Number: 1 Registered: Jun-07
| Posted on Thursday, July 12, 2007 - 03:58 pm: |
if someone can translate what joseph kubiak said, i would greatly appreciate it. |
Post Number: 1317 Registered: Feb-05
| Posted on Thursday, July 12, 2007 - 04:42 pm: |
HU=HeadUnit=radio/cdplayer,etc hahaha |
New member Username: Tblazer74
South Salem,
NY
Post Number: 3 Registered: Jun-07
| Posted on Saturday, July 14, 2007 - 02:24 pm: |
Stock car audio systems are mediocre at the best level. If you get a new head unit, it will make adding things like subs or more speakers later on easier. I doubt your stock head unit is putting out as many WRMS as any Aftermarket HU. You can get a good one for not that much money, and it will be worth it. You should really think about getting an amp for those speakers, and getting some in the back as well, but I don't know the RMS rating of those Pioneers off hand. Also, a Aftermarket HU makes playing MP3's much easier through an AUX cable or an integrated cable. |
