Thread: Screechy Tweeters?! |
Bronze Member Username: Vt_ahole
Post Number: 36 Registered: Jun-07
| Posted on Friday, July 06, 2007 - 09:58 am: |
i just hooked up my infinity kappa tweeters to an infinity reference amp and when i turn it up the tweeters are so loud its unbearable... and i dont think that its because the volume is too loud because i turned down the gain on the amp. any suggestions? |
Bronze Member Username: Sqcheap
Grand rapids,
Michigan
Usa
Post Number: 12 Registered: Jul-07
| Posted on Friday, July 06, 2007 - 05:47 pm: |
Are they hooked up to the crossover correctly? |
Silver Member Username: Believe
Illinois
Post Number: 189 Registered: Jun-05
| Posted on Sunday, July 15, 2007 - 12:02 am: |
the amp could be clipping the coils could be shot the tweeters need an equalizer |
Silver Member Username: Warlok
Orlando,
FL
Post Number: 351 Registered: Dec-05
| Posted on Monday, July 16, 2007 - 09:25 pm: |
lol, perhaps your crossover is bad. I woudl check the cross over like he said. Is it both of them , or just 1 ? And whats the x-over on ? |
