Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Need to know what size of speakers
Author Thread: Need to know what size of speakers
Username: Knag
Hey I'm having a tough time searching the web to find out what size my stock speakers are in my 1993 ford explorer eddie bauer edition, I would open the side of the door to figure it out but I don't wanna screw anything up lol, thanks.
Username: Delsole
Post Number: 1302
open em up thats the only way for you to be sure you know whats in there. if you take your time and be patient you wont screw anythng up.
or if you go to a dealer they have a program, search stock speakers under 93 explorer on ebay, even check out car domain, or jst wait till sombody comes along with the same vehical and tells you.
Username: The_image_dynamic
San Diego
Post Number: 2176
http://www.crutchfield.com/S-fIu9H45mV0N/cgi-bin/autoinfo/autoinfo.asp?cm_re=hea der*whatfits*_
Username: Knag
that site works good it says 6x8" thanks a lot
Username: Austinw
If you go to a bestbuy store and go to the car audio section they have a computer where you put in all of your info and it works really good
Username: Philly306
North carolina
Post Number: 124
bestbuy... are you kidding?
Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Need to know what size of speakers [ « Previous ] [ Next » ]
