Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Best 4"
Author Thread: Best 4"
Username: Justinp21
Wyoming
United States
Post Number: 15
Can anybody help me? i need some guidance concerning some good quality 4" speakers... any help would be appreciated... gracias!
Username: Alteraudiousa
Concord
Post Number: 1563
are you looking for coax's or components? And what is your budget? Do you want to spend about 350$ dollars for a set or 75$?
Username: Justinp21
Wyoming
United States
Post Number: 16
im just looking for some good coaxials, i dont want to spend more than $80 probably, got any suggestions?
Username: Antisign
Bakersfield, California
Post Number: 31
The Alpine type-s 4 inches are pretty good.
http://www.alpine-usa.com/US-en/products/product.php?model=SPS-10C2
Thats what i have in my car and they are pretty clear.
Username: Justinp21
Wyoming
United States
Post Number: 17
hey thanks... they look a little on the low side rms wise are you able to have them up very loud?
Username: Antisign
Post Number: 32
yea, i had 50 rms to each and they are crystal clear, and the good thing about them is they arent that deep.
Username: Justinp21
Wyoming
United States
Post Number: 18
yeah lookin at them it looks like they have some pretty good highs too... i might just buy, thanks Josh i appreciate it.
Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Best 4" [ « Previous ] [ Next » ]
