Thread: Any Genius's Out There?? |
Bronze Member Username: Jmp21
United States
Post Number: 14 Registered: Aug-06
| Posted on Tuesday, June 19, 2007 - 06:12 pm: |
Alright so my car uses 4x10 speakers in the front dash, i want to replace them, and im wondering what my options are... i havent been impressed w/ most of the 4x10s ive looked at... will anything else fit? thanks |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 4691 Registered: Jan-06
| Posted on Tuesday, June 19, 2007 - 06:49 pm: |
you could just use a 4" speaker and make a baffel of wood to cover up the extra space. you also may be able to fit a 5.25" in there as well. |
Bronze Member Username: Sqhoe
Huntington,
IN
Post Number: 27 Registered: Mar-07
| Posted on Wednesday, June 20, 2007 - 08:44 am: |
I dont know if they are still out there, but you use to be able to buy adapters that bolted into the 4x10 hole and you could mount a 5.25 to it. What kind of car is it? |
United States
Post Number: 16 Registered: Aug-06
| Posted on Wednesday, June 20, 2007 - 01:40 pm: |
I'll look into it, Its an 86 fiero |
United States
Post Number: 18 Registered: Aug-06
| Posted on Wednesday, June 20, 2007 - 01:41 pm: |
I'll have to look around to see if i can find some adapters... Its an 86 fiero |
