Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Need Recommendations/Feedback
Author Thread: Need Recommendations/Feedback
Username: Bigharv
Post Number: 17
The speaker setup in my car looks like this. I am gonna be running this setup with 2 loud 15"s on a JVC headunit.
(99 Tahoe)
2 tweeters up front
2 6.5" front door
2 6.75" rear doors
2 4x10" rear roof
+ Amplifier to power components
I want it to have descent sound quality, without distortion at high volumes. Not trying to spend a huge amount of money here but looking for a budget system that sounds clean. Please give me some recommendations!
Username: Jmp21
United States
Post Number: 13
Something like this would probably be sufficiant:
2 Infinity Kappa 10.7t 1" MMD Tweeters - $68
2 Infinity Kappa 62.7i 6-1/2" 2way Speakers- $100
2 Infinity Kappa 652.7i 6-3/4" 2way Speakers-$100
2 Pioneer TS-A4103 4"x10" Rear Deck Speakers-$70
1 Boss GT980 1200 watts,Riot GT Series 5-channel Amplifier- $155
Username: Adddisorder
West palm, Florida
Post Number: 4692
that boss amp wont work well and its crap anyway.
honestly you dont need that many speakers at all. i would jsut get 2 sets of PG octain zr speakers 6.5 and then a 4 channel amp that does 50-75rms a channel. maybe a alpine amp.
Username: Bigharv
Post Number: 19
ok well will the 6.5" speakers fit in a 6.75? do they make bigger brackets so it will fit without having to make modifications
West palm, Florida
Post Number: 4700
what you may have to do is take a piece of MDF or even plywood and use it to cover the 6.75 speaker hole and then cut out another hole inside the wood to fit the 6.5 speaker.
Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > Need Recommendations/Feedback [ « Previous ] [ Next » ]
