Thread: Expedition radio wiring help PLEASE!!! |
New member Username: Intimidatr
Post Number: 2 Registered: Jun-07
| Posted on Monday, June 11, 2007 - 09:50 pm: |
i am trying to wire a yu3f-18c868-aa i think from a 2002 expodition, into my 1998 expodition xlt witch has a f75f-19b165-da stereo in it now, the speaker wires seemed to match by color, but the acc and batery ac for power donnot match, if anyone could find out for me at least the power wire colors for the two radios that would be helpful or if anyone could find the full wire color code for both those radios i would be immensly thankful.....} |
Silver Member Username: Imalik
SD2.5......ED9.1=Boom,
New Jersey
Audioque...N...
Post Number: 372 Registered: May-06
| Posted on Tuesday, June 12, 2007 - 12:53 pm: |
Just buy a new wire harness for the 1998 |
Post Number: 3 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 07:15 pm: |
well you see that only solves half the problem,,, i dont know the colors of the wire on the new stereo and being an OEM the wire colors dont match the aftermarket colors on the female adapter, also, no conversion adapter is avalible that i can find |
Post Number: 4 Registered: Jun-07
| Posted on Thursday, June 14, 2007 - 09:11 pm: |
By the way, the expedition has "premium sound" witch as i understand makes a difference pertaining to wires |
Silver Member Username: Skies
Courtenay,
British Colu...
Post Number: 771 Registered: Aug-05
| Posted on Sunday, June 17, 2007 - 11:24 pm: |
http://www.the12volt.com/installbay/stereodetail/852.html |
