Thread: 5 1/4 speaker question |
Bronze Member Username: Solid8447
Post Number: 14 Registered: May-07
| Posted on Saturday, June 02, 2007 - 03:51 am: |
What is the best 5 1/4 speakers because my car just has four 5 1/4 speakers. I have about 250 to 300 for them. What are some ideas. Thanks |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 4493 Registered: Jan-06
| Posted on Saturday, June 02, 2007 - 11:04 am: |
are you going to be useing an amp? |
Gold Member Username: Delsole
Post Number: 1275 Registered: Feb-05
| Posted on Saturday, June 02, 2007 - 01:04 pm: |
cut out your doors etc. to make room to mount 6.5's |
Post Number: 19 Registered: May-07
| Posted on Saturday, June 02, 2007 - 07:26 pm: |
what wouild i use to cut it with |
West palm,
Florida
Post Number: 4500 Registered: Jan-06
| Posted on Saturday, June 02, 2007 - 10:27 pm: |
dont cut it thats unnecessary 9times out of 10. depends what your looking for in a speaker. high quality sound and strong midbass i would do 6.5 or 7" you should be able to use a peice of 1/2" MDF and cut out a hole for the new speaker and place it over the existing hole. and that is basically that. |
