Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > 6.5" speaker component set
Author Thread: 6.5" speaker component set
Username: Djhasanicesoundsystem
Vista, Ca
Usa
Post Number: 127
what is a good 6.5" component speaker set for 300 and lower?
Username: Sqhoe
Huntington, IN
Post Number: 16
ADS 346cs. Look on ebay.
Vista, Ca
Usa
Post Number: 129
what company makes them?
Username: Pjg
Here are some options. Most prices come from woofersetc.com. Rainbow is from speedsound.com and DLS is from mobilesq.com.
Rainbow: Power Line CMX 265 ($300)
Morel: Tempo 6 ($240)
Boston Acoustics: SL60 ($225)
DLS Reference MS6 ($255)
I haven't heard any of these, but from everything I've read in the research I'm doing these are the brands that people really like and the models in your price range. There are some MB Quart and Focal's in your price range but people complain that the highs are too harsh/sharp from these two brands.
Username: Alteraudiousa
Concord
Post Number: 1557
if you are interested in a set from CDT, PM me and I can get you a direct quote.
Username: Adddisorder
West palm, Florida
Post Number: 4467
^^^^so you know PJ i would not buy from speedsound or from mobilesq iv heard about bad things from both.
Vista, Ca
Usa
Post Number: 132
ok what are CDT cuz i really just started in speaker area
Username: Ctmike
Ct.
Post Number: 4490
www.cdtaudio.com
Username: Sqhoe
Huntington, IN
Post Number: 18
ADS is made by DEI now. I have a set of them and love them.
Vista, Ca
Usa
Post Number: 133
what about these are they ok
Elemental Designs DLS MS6A
West palm, Florida
Post Number: 4477
they arnt bad.
Username: Matt12490
California
Post Number: 2439
BUT you can do better.
Username: 350zspl
Delray beach , Florida
Usa
Post Number: 21
were can rainbow be bought from
Username: Pjg
You can get Rainbows from premier-audio.com or from 6spdcoupe on www.caraudio.com/forum. Mat D mentioned above that speedsound.com isn't a good source, but these other two options should work well.
West palm, Florida
Post Number: 4488
^^6spdcoupe aka don is a good guy and will hook you up. aaron is also a good guy to deal with he will give you better prices then on the website.
Username: Ryant
Post Number: 37
i'm also in the market for some components - what do you guys think of the polk db6500?
Username: Ryant
Post Number: 38
or the polk db6501? inifinity reference 6020cs? focal 165a?
i will get an amp, just not right away. so i want something that will sound good even without an amp.
West palm, Florida
Post Number: 4511
the focals are nice. you will need an amp otherwise you will not get much out of speakers.
Username: Ryant
Post Number: 39
without an amp, is there not going to be a big difference between the focals (or whatever i choose) and the factory set? or is that i just won't be utitilizing everything they have to offer?
West palm, Florida
Post Number: 4514
well the HU gives them a small amount of power then what they really need. i would put them in and they will probably be on par with the stock but once you put an amp on them you will see a world of difference.
Username: Matt12490
California
Post Number: 2466
Components with headunit power = waste of money for components. I like how Mat put it, you wouldn't really notice a difference between them and your stock speakers.
Bottom line: components and amps make a beautiful couple.
Username: Ryant
Post Number: 40
so for the components, would you recommend the focals? i want to stay around the price range of no more than $250 for the speakers.
also, what amp would you recommend? i doubt i will be doing anything with the back speakers any time soon (or maybe even not at all).
(i will be getting tweeter to install both the speakers and amp)
I APPRECIATE THE HELP!
West palm, Florida
Post Number: 4518
sundown 100.2 would be nice, whats your budget for an amp. i think chad lee runs those focals or the 3way set or something pm him and ask how he likes them.
Username: Ryant
Post Number: 41
i would like to spend around $200 for an amp (no including installation)
West palm, Florida
Post Number: 4522
i think you can get the sundown for around 225, you also might want to look into some kicker amps from hifisoundconnection.com they have great prices. also directed makes nice amps.
Username: Ryant
Post Number: 42
are there any kicker amps that you would recommend? i'm new to this so it's all greek to me.
btw, my hu is a pioneer premier 790bt
Username: Sheriff
Post Number: 477
Either zx200.2 or zx350.2 depending on what ohm the comps are.
Username: Ryant
Post Number: 43
i will probably go with the focal 165a comps
Username: Ryant
Post Number: 44
say i don't get an amp, would you recommend going with coaxials? and what coax's would you recommend?
Username: Joe96sl2
Try out some of exile's X65's for coaxials, I've heard nothing but good things about them.
http://exileaudio.com/2006/products/coaxial/
Username: Joe96sl2
A pair of x65 exile coaxials are only $120. excellent price and company, 2 year parts and labor warrenty. 'nuff said
Username: Ryant
Post Number: 45
so without an amp, what is the difference between the comps and the coaxs just running off the hu? i understand that the comps need an amp to fully maximize their potential - but will the comps and coaxs sound about the same just running off the hu? or do the comps still provide a noticeable difference?
West palm, Florida
Post Number: 4528
its hard to tell what would make you happy, in car audio its best to just do it right the first time and go all out.
Username: Ryant
Post Number: 46
that makes a lot of sense. i got a new car and am getting a new hu (pioneer premier 790bt) to go along with it. i want new speakers too but i'm a newb when it comes to speakers. so i'm just trying to learn all i can before i invest in speakers. i'm not opposed to an amp but i'm not hard core into car audio - meaning i'm not going to be getting a sub or seeing how loud i can get my system. but i do want something that isn't too expensive (maybe looking to spend around $600 including installation) and want a clear sound that will be a big improvement over my factory set.
West palm, Florida
Post Number: 4531
then defiantly get some nice comps and an amp.
Username: Ryant
Post Number: 47
appreciate the help. i can't wait!
Home > Message Board > Car Audio > Speakers > Archive through August 02, 2007 > 6.5" speaker component set [ « Previous ] [ Next » ]
