Thread: New systemI |
Bronze Member Username: Kewinn89
Grand bay,
Alabama
Usa
Post Number: 69 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:16 pm: |
I'm getting rid of my old system and i'm getting me a new one! where should i start i have a 350 spending limit. could someone please help me?? |
Silver Member Username: Mmaudioconcepts
Murray,
KY
Post Number: 155 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:28 pm: |
350 for everything? start with a new head unit http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3934&C FID=4619803&CFTOKEN=8fb13e7a9e717083-BFC55481-1422-7C6E-5071D8AB426BDDFB |
Grand bay,
Alabama
Usa
Post Number: 70 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:30 pm: |
well i guess i could spend about 500 for eveything! |
Murray,
KY
Post Number: 157 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:38 pm: |
ok are u looking for sql or spl or sq and what speaker sizes? |
Murray,
KY
Post Number: 158 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:39 pm: |
do u want just subs and amps or speakers and headunit too |
Grand bay,
Alabama
Usa
Post Number: 71 Registered: Dec-06
i was thinking about buying me 2 15'' lanzar subwoofers and a 4000 watt lanzar amp off of ebay! i don't know what type of head unit i'm getting though. |
Murray,
KY
Post Number: 160 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:43 pm: |
get these http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2146&C FID=4619803&CFTOKEN=8fb13e7a9e717083-BFC55481-1422-7C6E-5071D8AB426BDDFB they get loud, sound good, and they only need 250 watts each my friend had these and his window flexed about half an inch |
Murray,
KY
Post Number: 161 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:45 pm: |
and get this amp http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=374&CF ID=4619803&CFTOKEN=8fb13e7a9e717083-BFC55481-1422-7C6E-5071D8AB426BDDFB |
Grand bay,
Alabama
Usa
Post Number: 72 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:46 pm: |
http://cgi.ebay.com/2-LANZAR-15-4000W-4-OHM-DVC-SUBWOOFERS-SUBS-NEW-PAIR_W0QQite mZ120124492951QQihZ002QQcategoryZ18804QQrdZ1QQcmdZViewItem http://cgi.ebay.com/NEW-4000-WATT-LANZAR-VIBE286-Car-Audio-Amp-Amplifier_W0QQite mZ220114068445QQihZ012QQcategoryZ39732QQrdZ1QQcmdZViewItem what about this?? |
Murray,
KY
Post Number: 164 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:47 pm: |
i promise you it will be way better than the lanzar system u have picked out, max watts dont mean anything, its all about RMS. Just because a sub can handle more watts doesnt mean its better. An efficient sub is better than a power hungry sub if it can do the same or better with less power. |
Grand bay,
Alabama
Usa
Post Number: 73 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:49 pm: |
right now i have 2 12'' kenwood typhoons subwoofers and i have a 520 watt spl amp it sounds really good but, i want a little more. |
Murray,
KY
Post Number: 165 Registered: Jan-07
Lanzar has poor build quality unless it is the OPTI line. I wouldnt get them. but it is your money |
Grand bay,
Alabama
Usa
Post Number: 74 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:51 pm: |
what should i do about a head unit?? |
Murray,
KY
Post Number: 166 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:52 pm: |
i promise the memphis setup i suggested will be a lot better than the system u have now and the lanzar system..or i could recocmend a single sub, a high end one, and another amp. or do u have to have two subs |
Grand bay,
Alabama
Usa
Post Number: 75 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:53 pm: |
i could get three subs because i have a three slotted box. |
Murray,
KY
Post Number: 167 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 04:55 pm: |
pioneer http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5160&C FID=4619803&CFTOKEN=8fb13e7a9e717083-BFC55481-1422-7C6E-5071D8AB426BDDFB |
Grand bay,
Alabama
Usa
Post Number: 76 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 04:57 pm: |
o okay. what about soundstream?? |
Murray,
KY
Post Number: 169 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 05:01 pm: |
soundstream is good |
Grand bay,
Alabama
Usa
Post Number: 77 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 05:03 pm: |
well i might buy the memphis system or either a soundstream system! what kind of system do u have?? |
Murray,
KY
Post Number: 170 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 05:05 pm: |
i currently don't have one, i install systems on a daily basis. i am saving at the moment because im opening up a club and a car audio shop |
Murray,
KY
Post Number: 171 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 05:07 pm: |
my las system was memphis subs and directed amps |
Grand bay,
Alabama
Usa
Post Number: 78 Registered: Dec-06
o okay thanks for your help! |
Murray,
KY
Post Number: 172 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 05:08 pm: |
eclipse head unit( eclipse is one of the best brands for head units |
Grand bay,
Alabama
Usa
Post Number: 79 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 05:09 pm: |
okay i'll go check some of them out! |
Grand bay,
Alabama
Usa
Post Number: 80 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 05:16 pm: |
is this a good one! http://cgi.ebay.com/Eclipse-CD2000_W0QQitemZ220115017144QQihZ012QQcategoryZ18798 QQrdZ1QQcmdZViewItem |
Murray,
KY
Post Number: 173 Registered: Jan-07
| Posted on Thursday, May 24, 2007 - 05:56 pm: |
yes eclipse doesnt make a bad unit at all. just, the higher the model number the more features, but yes this is an entry level unit but it is still good |
