Home > Message Board > Car Audio > Amplifiers > Archive through May 25, 2007 > Amp help plzzz
Author Thread: Amp help plzzz
Username: Basssjunckie
Post Number: 15
is a two channel amp allright to use if your only powering one sub?
Username: Van_man
Boston South, MA
Post Number: 2438
All depends on the amp, if it can be bridged. May only bridge to 4 ohm. Also what sub.
So yes it can be done, but it needs to be compatible.
Username: Nd4spd18
Southeast PA
Post Number: 2626
Sure but you have to bridge it, which means that on most amps you have to run it at 4 ohms.
and triple thread post FTL.....
Username: Dakangofkrunk16
Post Number: 260
"and triple thread post FTL"
Ha Ha i was about to say that
Post Number: 261
Also Some Mono Amps have it like you can hook up two subs, maybe it is a mono amp and you don;t know it
Home > Message Board > Car Audio > Amplifiers > Archive through May 25, 2007 > Amp help plzzz [ « Previous ] [ Next » ]
