Home > Message Board > Car Audio > Amplifiers > Archive through May 25, 2007 > Is this amp good
Author Thread: Is this amp good
Username: Italianplaya
is the AUDIOBAHN A8002V amp good. im powering 2 12 comp vr subs at 2 ohms each. and want each sub to get 400 rms a peace thanks for the help.
Username: Freezeman_7
C.FREE
Post Number: 1190
no. there are waay better amps that the ab
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4625
if they're DVC 2 ohm then grab a ZX 750.1
If they're DVC 4 ohm, grab a massive audio p1000
Username: Nd4spd18
Southeast PA
Post Number: 2576
No audioburn is not good..... but those amp that juliob listed are
Username: Nvmyboom
Post Number: 115
hey, i have two dual 4ohms, would that p1000 push them better than a crappy Lanzar Vibe 286? and is there any more amps that would push these subs good at a cheap price?
Username: 04redmach1
Columbus, GA
Post Number: 781
The P1000.1 would be perfect for them. Good amp and 2 year warranty. Email me.
Kevin
lowhz01@yahoo.com
Username: Jkidder
Spring hill, Florida
Usa
Post Number: 655
that audiobahn really isnt all that bad. i remember ppl on here used to have them. overheat and not very many tuning options, bad quality but put out pretty much wat they say.
Username: N2audio
Lawrence, Ks
Post Number: 1315
"would that p1000 push them better than a crappy Lanzar Vibe 286?"
The massive won't produce much mower power than the 286, but it would be less stressful on your electrical system. If you're looking for around 1000w at 1 ohm the Hifonics bxi1206d comes to mind.
Username: Killswitchjd
Post Number: 610
I will admit I have the pos audiobahn, the only overheating was from clipping due to improper gain settings. I fixed that and have had no problems, pushes the cvr's I have nicely for a budget system. Probably only really puts out 600 rms total but thats enough for these subs as a starting point to save money.
Home > Message Board > Car Audio > Amplifiers > Archive through May 25, 2007 > Is this amp good [ « Previous ] [ Next » ]
