Thread: Amp settings |
Bronze Member Username: Lord_victor
Post Number: 11 Registered: Apr-07
| Posted on Sunday, May 20, 2007 - 05:56 pm: |
two 4 ohm 400 rms subs, 900 rms x 2ohm amp need help with gain and input sensitivity, and a quick stupid question my lpf has a range of 50-200 what should i set that 2? and as for bass boost its best ot avoid that right |
Silver Member Username: Mmaudioconcepts
Murray,
KY
Post Number: 138 Registered: Jan-07
| Posted on Sunday, May 20, 2007 - 07:14 pm: |
bass boost - off lpf 60-100 most 80 is what i use |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2575 Registered: Jul-06
| Posted on Sunday, May 20, 2007 - 11:34 pm: |
No bass boost, LPF 80-100 wherever it sounds best, for setting gain: http://www.subwoofertools.com/forum/setgain.asp http://mobile.jlaudio.com/support_pages.php?page_id=143 |
