Thread: Small Sub system suggestions? For the lady... |
Bronze Member Username: Shorterthanrich
Post Number: 52 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 02:25 am: |
Ok I'm trying to set my girlfriend up with a nice little sub system. She has decent comps in her car but they have no low end. She's not huge on bass, but I've got her convinced that the sound just is not "full" without some bass in there. I figure a decent 10" woofer in a sealed box would do the trick. No need for more than 200 Watts RMS I would think. The 12" 250 watt RMS bazooka I had in my car is way more than she needs (which is not saying much...). Any system suggestions? Particularly if anyone is selling or knows someone selling equipment that fits. Budget is probably the most important aspect. I'm lookin on here and craigslist. I prefer getting decent stuff through someone on here or online so she can get a warranty. My aim is <$300. BTW she has a teeny little '99 Saturn SL2. I don't feel like changing the in car speakers or adding more in the car - I think just adding a dedicated sub or two would be the easiest thing to do. |
Post Number: 54 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 03:05 am: |
There's lots of cheapo bazooka and pyle tube woofers. The bazooka I had sounded nasty and muddy...but for way cheap in a simple setup like a tube is it almost worth it? I'm open to all input. <$200 or <$300 for everything - including wires and box. If I can find a decent amp at a price in her budget, I'll try and get these.. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=004&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D140118603444%26%26 |
Post Number: 55 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 03:06 am: |
There's lots of cheapo bazooka and pyle tube woofers. The bazooka I had sounded nasty and muddy...but for way cheap in a simple setup like a tube is it almost worth it? I'm open to all input. <$200 or <$300 for everything - including wires and box. If I can find a decent amp at a price in her budget, I'll try and get this guy.. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=004&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D140118603444%26%26 |
Post Number: 56 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 03:16 am: |
scratch the link in the last posts. |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 278 Registered: Nov-06
| Posted on Sunday, May 20, 2007 - 06:15 am: |
just get a pioneer 10" sub and a prefab box for her, and get a amp taht does about 200rms. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4622 Registered: Dec-05
| Posted on Sunday, May 20, 2007 - 08:56 am: |
simple rich. You can get a 10" infinity which is very good for that application. Also you can grab pioneer or any brand shallow subs. They save space and can play good notes. Don't get cr4ppy stuff to your girl man haha, froget bazooka or pyle |
Gold Member Username: Ctmike
Ct.
Post Number: 4398 Registered: Feb-06
| Posted on Sunday, May 20, 2007 - 09:15 am: |
10" idq. |
Silver Member Username: Jkidder
Spring hill,
Florida
Usa
Post Number: 620 Registered: Nov-05
| Posted on Sunday, May 20, 2007 - 11:10 am: |
dd 9512 n' an orion 2500. but no seriously, DD 510 and kicker 300 watt mono |
Post Number: 57 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 01:36 pm: |
I'm thinkin an rd 300 studio series 300 watt RMS 10", and possibly that kicker 300 mono amp... Is anybody selling a 300 watt rms (ish) mono amp? |
Post Number: 63 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 04:34 pm: |
* 300 watt RMS @ 2 ohms |
Gold Member Username: 420alldaylong
Post Number: 1747 Registered: Sep-06
| Posted on Sunday, May 20, 2007 - 05:07 pm: |
Bangin little system http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3754 http://www.sonicelectronix.com/item_3407_Kicker+05CVR124.html |
Silver Member Username: Waterboy2289
Georgia,
DiRtY SoUtH ...
2 18 SX w/ ...
Post Number: 447 Registered: Jan-06
| Posted on Sunday, May 20, 2007 - 06:14 pm: |
^^^Good selection. Same amp for $18 cheaper: http://cgi.ebay.com/BRAND-NEW-07-KICKER-ZX300-1-300-W-MONO-AMP-BASS-KNOB_W0QQite mZ180117618600QQihZ008QQcategoryZ64570QQrdZ1QQcmdZViewItem Then throw in this box: http://cgi.ebay.com/12-SEALED-MDF-SUBWOOFER-SUB-ENCLOSURE-BOX-NEW-GRAY_W0QQitemZ 300111282526QQihZ020QQcategoryZ50568QQrdZ1QQcmdZViewItem And this amp kit: http://cgi.ebay.com/8-Gauge-Amp-Wiring-Kit-8Gauge-Amplifier-Hookup-Wires_W0QQite mZ200110662433QQihZ010QQcategoryZ71529QQrdZ1QQcmdZViewItem You will be good to go! |
Post Number: 69 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 07:13 pm: |
Joey and Matt, that's awesome. Everything you said is what I'm goin for. The amp on ebay is totally optimal - thanks for that. I'm gonna get it. That box is probably perfect. I'm waiting on a quote on a box from someone but I'll prob end up with the one off ebay. Is that brand of wire any good? If not I can just get some scosche |
Post Number: 4627 Registered: Dec-05
| Posted on Sunday, May 20, 2007 - 10:07 pm: |
i wouldn't use kicker sub for my girl IMO:P i'd pick infinity cuz of SQ, but yeah that's not bad at all. Good bass system. Rich, about wires, if they're 8AWG for real, then brand shouldn't matter. |
Post Number: 73 Registered: Apr-06
| Posted on Sunday, May 20, 2007 - 11:18 pm: |
true about the wires. That kit is SO cheap, i'll probably go with it. I'm using a RD audio 10" sub instead. this one http://www.rdaudio.net/woofers/studio.php And the kicker amp mentioned above. |
Bronze Member Username: Kpa2727
Post Number: 82 Registered: May-07
| Posted on Thursday, May 24, 2007 - 04:37 pm: |
i recommend a infinity bass link, they sound awsome aren't a pocket buster, won't rattle u to death and all ur works done. justget the warrenty and wire power and audio thats it. |
