Home > Message Board > Car Audio > Amplifiers > Archive through May 25, 2007 > Good 2 channel amp?
Author Thread: Good 2 channel amp?
Username: Armstrong
Post Number: 20
hey, what's a good 2 channel amp that puts out 80-100 rms at 4 ohms? my budget is $150. it is gonna be used to power a set of phoenix gold rsd6.5 comps. i've looked on ebay and i've found these amps... are any of these good or are there others you guys could recommend?
JL e2150
Rockford Fosgate P325.2
MTX TC3002
Kicker Kx250.2
Username: Nd4spd18
Southeast PA
Post Number: 2546
The Kicker is the best out of those. Kicker amps are good quality.
Username: Armstrong
Post Number: 21
anybody else have any input?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4621
nick, i'm going to buy those components, so when you get it give me a PM with your opinion.
Rockford, kicker,jl they're all good choices
Username: Armstrong
Post Number: 22
anyone else?
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 266
The Kicker is nice, could do a Rockford P200.2 http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=109
Username: Armstrong
Post Number: 23
yea, i'm pretty much trying to choose between the jl, kicker, or rockford. it's a tough choice. since they're all known to make good amps, would i really even notice much of a difference between them?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4634
no. Maybe in durability. I'd pick kicker IMO.
Username: 04redmach1
Columbus, GA
Post Number: 794
I can give you a good deal on a Massive Audio P200.2 or Cadence FXA2100. Both do 100x2 @ 4 ohms.
Kevin
lowhz01@yahoo.com
Home > Message Board > Car Audio > Amplifiers > Archive through May 25, 2007 > Good 2 channel amp? [ « Previous ] [ Next » ]
