Thread: Hu rms + amp rms |
Bronze Member Username: Schinner
Post Number: 36 Registered: May-07
| Posted on Friday, May 18, 2007 - 07:12 pm: |
my hu puts out 17 watts rms....amp puts out 55 watts rms per channel.....do you add them to find the total out put or what? |
Platinum Member Username: James1115
Use a simple...
Post Number: 10096 Registered: Dec-04
| Posted on Friday, May 18, 2007 - 07:54 pm: |
explain a little more about your set-up or what you plan on doing. |
Silver Member Username: Imalik
SD2.5......ED9.1=Boom,
New Jersey
Audioque...N...
Post Number: 321 Registered: May-06
| Posted on Friday, May 18, 2007 - 07:56 pm: |
No... your amp is getting a signal from your RCA plugs, not power...So your amp is putting out its power to what you have hooked up to it...the 17 watts from your HU is powering the stock speakers |
Post Number: 42 Registered: May-07
| Posted on Friday, May 18, 2007 - 08:51 pm: |
whoa i get it...stupid me nvm thanks guys |
