Thread: Desperately need fuse help |
New member Username: Hokiefan4life100
Post Number: 10 Registered: May-07
| Posted on Friday, May 18, 2007 - 12:54 pm: |
hey, i keep blowing my fuse, and i think i now know why. i have an RE 12.1 and a jl audio 300/2 amp and the stock fuses they gave me are only 60 amps. The problem is they are the circular tube fuses, AGU i believe. Do i need to switch to an ANL holder and get a 150 amp fuse? Will that stop me blowing all of my fuses? What other things could cause it? |
Gold Member Username: Oleg
Santa Monica,
CA
Post Number: 1369 Registered: Nov-04
| Posted on Friday, May 18, 2007 - 01:01 pm: |
Are you talking about the inline fuse by the battery then? If so, then your fuse rating will depend on your wire size. What size is your power wire...4awg, 2awg? You can find your fuse rating at www.bcae1.com/fuses |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 2509 Registered: Jul-06
| Posted on Friday, May 18, 2007 - 02:24 pm: |
Use that link ^^^^^^ You CAN NOT install a fuse larger than what is specified for your wire. If your amp draws too much current for you wire, you have to run heavier gauge wire. |
