Thread: Gain settings |
New member Username: 98lx
Post Number: 1 Registered: May-07
| Posted on Wednesday, May 16, 2007 - 10:56 pm: |
hey guys. i have a headunit that is advertised as having a "high voltage, 5V" output. i recently purchased an alpine pdx amp and am having trouble setting the gains. the dial is labeled as follows: all the way to left is "min", which the manual says is 4 volts. At the top center of the dial, there is a sign that says "NOM". And all the way to the right is max. What should I set the gains at given i have a 5 volt output? I wanna get the most sound out of my amp as possible. thanks. |
New member Username: Jayem
Post Number: 6 Registered: Apr-07
| Posted on Thursday, May 17, 2007 - 07:49 am: |
How to set gain: http://www.subwoofertools.com/forum/setgain.asp You need something like a 50Hz test tone CD also. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1308 Registered: Mar-04
| Posted on Thursday, May 17, 2007 - 09:03 am: |
it should be at or very near the 4v setting |
Post Number: 5 Registered: May-07
| Posted on Thursday, May 17, 2007 - 10:06 am: |
thanks guys. i appreciate it. |
