Home > Message Board > Car Audio > Speakers > Archive through June 02, 2007 > $300 Budget
Author Thread: $300 Budget
Username: Skies
Courtenay, British Colu...
Post Number: 722
Looking at a set of eDi 6000s v.2's for rear, and was wondering what to throw up front, 6.5" preferably component. About $200 for fronts if you agree that the eDi's would be best suited for the rear. Fronts will be amplified with about 100-120wrms, and rears powered by deck.
Username: Skibum12189
Cleveland
Post Number: 576
http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogn o=SSCS6
http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogn o=SSX615
Once you save up for a while, you could give those comps about 150 rms at least and they'll scream. Then you could take the 100 watt rms amp and put it to the coaxials. It would be amazing.
Home > Message Board > Car Audio > Speakers > Archive through June 02, 2007 > $300 Budget [ « Previous ] [ Next » ]
