Thread: My room is killin in the chi |
New member Username: Banginhard
Post Number: 2 Registered: May-07
| Posted on Wednesday, May 16, 2007 - 01:02 am: |
i got 4 12" kickers cvr's and a BA4000 4 channel amp ... what type of power conerter do i need to hook up in my room |
Bronze Member Username: Kpa2727
Post Number: 70 Registered: May-07
| Posted on Wednesday, May 16, 2007 - 01:58 am: |
as i've stated in the other thread thats just not practical by a ounce of rational thinking. hell a arch welder would need less power. |
Gold Member Username: Carguy
Post Number: 6215 Registered: Nov-04
| Posted on Wednesday, May 16, 2007 - 09:07 am: |
You'll need a 12v powersupply. You can use the ones made for ham radio. Look on eBay or any ham radio stores. They're not cheap however. Some of them will range in price $150 - $500. |
Gold Member Username: Johnfiac
A-ToWn,
Kingkong ain...
I got Chuck ...
Post Number: 2850 Registered: Mar-06
| Posted on Wednesday, May 16, 2007 - 11:09 pm: |
Buy some dayton plate amps it will work out much better you can get some that do 1000rms each |
Silver Member Username: Rtyauch301
Post Number: 169 Registered: Aug-06
| Posted on Wednesday, May 16, 2007 - 11:29 pm: |
oh peeps its just a guess i dont know if it will work but if he gets one of those 200amp car battery chargers wouldnt that work their only like 69 dollars at walmart |
A-ToWn,
Kingkong ain...
I got Chuck ...
Post Number: 2852 Registered: Mar-06
| Posted on Thursday, May 17, 2007 - 12:33 am: |
Im sure there is no way in hell its going to do 200A .....expeccialy nly costing 69$ at walmart... LOL but even if her did that he wouldnt be able to use most batterys in the house... batterys charging put off fuses... |
A-ToWn,
Kingkong ain...
I got Chuck ...
Post Number: 2853 Registered: Mar-06
if HE did that* |
