Thread: Need i deas for speakers |
Silver Member Username: Djhasanicesoundsystem
Vista,
Ca
Usa
Post Number: 110 Registered: Feb-07
| Posted on Tuesday, May 15, 2007 - 02:21 pm: |
any good speakers that are not to expensive but can hit real good and make some noise. |
Vista,
Ca
Usa
Post Number: 111 Registered: Feb-07
| Posted on Tuesday, May 15, 2007 - 02:22 pm: |
and they need to be 5.25" front and 6x9 in the rear |
Gold Member Username: Ctmike
Ct.
Post Number: 4361 Registered: Feb-06
| Posted on Tuesday, May 15, 2007 - 06:06 pm: |
by "not to expensive" exactly how much you talking about and are you looking for a component set for the front or just coaxs'? |
Vista,
Ca
Usa
Post Number: 112 Registered: Feb-07
| Posted on Wednesday, May 16, 2007 - 02:41 am: |
well im kinda a nood so what is the difference between them and which ones sound better amd are cheaper. around 100-200 at most. kinda on a limited budget cuz just spent $$ on prom and my job is only paying me 8 an hour + i only work 20 hours a week and gotta pay 25 a week 4 insurence |
Bronze Member Username: Wrencher
Brighton,
Illinois
Post Number: 40 Registered: Apr-07
| Posted on Wednesday, May 16, 2007 - 10:54 am: |
I'd recomend in your case to just forget about the rear set and spend it on the front set. You don't really need rear speakers anyway. Are you going to be using an amp or just running it off the head unit? |
New member Username: Salmiery
Martinsburg,
WV
Post Number: 8 Registered: May-07
| Posted on Monday, May 28, 2007 - 02:17 am: |
I have a similar setup - I would have access to a crappy 500 watt amp that is supposed to be 2 channel but for some reason i beleive it is a fake. I bought a sub/amp combo and the amp was a Patriot 2 channel 500 W amp that was bridged for the subs so i think it just says it is 2 channel when in fact its just a 1 channel.. I could use this for the speakers.. What would you suggest (under 150 per pair - just need mids/highs) |
Vista,
Ca
Usa
Post Number: 125 Registered: Feb-07
| Posted on Tuesday, May 29, 2007 - 01:54 am: |
ya im gonna us an amp. what type of speaker is better for a daily driver and can get loud when turned up? |
