Thread: 4 , 12 ' infinitys is it possible to run 4 subs off any amp? |
Bronze Member Username: Kpa2727
Post Number: 47 Registered: May-07
| Posted on Monday, May 14, 2007 - 03:34 pm: |
i'm not trying to get annoying but please bare with me. is itpossible to run 4 of the same size subs off any amp? cause i'm gonna go with this amp http://www.bestbuy.com/site/olspage.jsp?skuId=8222345&st=alpine&type=product&id= 1166840026929 i got sore credit so i'm kind of stuck gettin it from best buy but this is the strongest i seen yet from them. also now that i will be running just 2 12's at 4 oms's and thier total rms if u add them is 600 rms, 300 rms a woofer. |
Bronze Member Username: Lowgan
Post Number: 37 Registered: Feb-07
| Posted on Monday, May 14, 2007 - 06:59 pm: |
how much store credit do you have? |
Post Number: 49 Registered: May-07
| Posted on Monday, May 14, 2007 - 08:49 pm: |
i only had 299 store credit i just added the 100 and bought the alpine mrp 850 it produces 500 w rms x1 at 4 ohms and my 12' subs are 300rms a woofer and wired at 4 ohms. so apposed to my last amp at 456 rms this one should run ok i assume. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1303 Registered: Mar-04
| Posted on Monday, May 14, 2007 - 11:04 pm: |
run them parallel, and the amp will see 2 ohms that will give you 400w+ per sub -- be conservative with the gain. http://crutchfield.custhelp.com/rnt/rnw/img/enduser/Mono_2-4OSVC.jpg edit - forget it -- you have dvc 4's, not svc's. That diagram won't work for you |
Post Number: 53 Registered: May-07
| Posted on Monday, May 14, 2007 - 11:08 pm: |
i just posted a new topic on it as i got the email. the calculator rated my amp at 44.7 volts so i assume 42 or 40 should give me lead way so i don't hurt them? |
