Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > HPF a little too high?
Author Thread: HPF a little too high?
Username: Sweatyogre
Erie, PA
Post Number: 178
I'm thinking about getting a Memphis 16-MCA300 amp to power the door speakers in my Explorer, but I don't like the lowest frequency for the high pass filter. The lowest frequency you can adjust it to is 400 Hz. A cheaper Memphis amp with the same output, the 16-PR300.2 can be set as low as 40 Hz.
Maybe I'm wrong, but wouldn't 400 Hz be really high for a HPF?
Username: Nd4spd18
Southeast PA
Post Number: 2358
That amp can be set as low as 40hz also.
Read the description:
http://www.memphiscaraudio.com/products/details.asp?cat=&id=11&p=2
Username: Oleg
Santa Monica, CA
Post Number: 1361
I think the X10 filter option is for bi-amping so you can set it a lot higher for the tweeters. X1 option is what you'd want for components and such. M.S. is always on the ball with this kinda sh!t lol
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > HPF a little too high? [ « Previous ] [ Next » ]
