Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Amp for kickers
Author Thread: Amp for kickers
Username: Mike11mac11
Grand rapids, Michigan
Usa
Post Number: 27
sry this is prolly a stupid question but im new to all this so any help will be nice. i have to 12" kicker compVR's and i have no idea what amp i should be getting
Username: Imalik
SD2.5ED9.1=Boom, New Jersey
Audioque...N...
Post Number: 296
I had a pair of 12"Cvr...I used a Hifonics BXI1206d did a real Good job...And its about $230 brand new.
Do you have 2ohm or 4ohm subs.
Usa
Post Number: 28
4ohm
Usa
Post Number: 29
whats better 2ohms or 4
Username: Imalik
Audioque...N...
Post Number: 301
They are both good, just different wiring options
Username: 420alldaylong
Post Number: 1709
2ohm or 4ohm doesn't make it better thats for wiring.
Heres how you would wire them to 1ohm.
http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=2&impedance_of_subs=4o hm_dvc&x=133&y=12
This amp will be great for those subs you have.
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=2635
Username: Imalik
Audioque...N...
Post Number: 302
Second link is wrong Joey
Post Number: 1710
How is it wrong?
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 12238
1205 vs 1206
Post Number: 1715
Samethang
Username: Wrencher
Brighton, Illinois
Post Number: 36
Actually the impedence you run on a sub has an effect on the sound quality. The lower the impedence (like 8 ohm) the better the SQ. But if you want more punch then wire it with more impedance (like 2 ohm).
Username: Oleg
Santa Monica, CA
Post Number: 1359
Sunny is right, except that 8ohm is the higher impedance, not a lower one. Mike, what's your budget? Chances are you can do a lot better than hifonics.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Amp for kickers [ « Previous ] [ Next » ]
