Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Replacing cassette player wih cd Help!!
Author Thread: Replacing cassette player wih cd Help!!
Username: Addisty
UK
Post Number: 21
can someone help me please, i'm trying to replace the cassette player in my bmw 318i 2002reg with a cd player and also hook amp and subs with it. My problem is i don't know which wire does what at the back of the cassette player.Can someone please show me the wiring diagram. Thank you
Username: Imalik
SD2.5ED9.1=Boom, New Jersey
Audioque...N...
Post Number: 299
You need to get a wire harness...once you disconnect the wires from the old radio, plug in the harness and the wires will be color coded, you just match them up, there will be a diagram that will come with the harness explaining what each wire controls.
Username: Addisty
UK
Post Number: 22
Thanks I-Malik can you please tell me what the wire harness looks like and where to get it from Thanks
Username: Imalik
Audioque...N...
Post Number: 304
It should be here
http://www.installer.com/wires/index.html?gclid=CJrI3rOQjIwCFSMKGgodzC0iBw
Username: Addisty
UK
Post Number: 23
thanks I-Malik It came with a standard CD changer as well. I bought the wiring harness for the CD player but the steering volume controls on the steering wheel and the CD changer does not work can someone please tell me how to get it working,and how do I take the panel under the glove compartment to get the rca cable through to the head unit?
Thanks
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Replacing cassette player wih cd Help!! [ « Previous ] [ Next » ]
