Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Amp/alt/batts
Author Thread: Amp/alt/batts
Username: Mikeneufeld
Abbotsford, BC
Post Number: 47
for around 5k of clean watts... whats recommended if the alt is 200 amp? ( for batteries) and for a daily system....
Username: Glasswolf
Wisteria, Lane
Post Number: 12027
depends a lot of your listening preferences, volume habits, etc..
200A would provide about 2200 watts of power (not factoring in efficiency of amps) after the car's needs.
if you want to supply 5Kwatts of power, you'll need a second 200A alternator, and at least a couple Kinetik 2400 series batteries or equivelant.
also, battery isolators, 0 or 00 AWG wire, and so forth.
Username: Nd4spd18
Southeast PA
Post Number: 2347
^^^ Your question just got answered by the most knowledgeable member on the forum Mike
A few big batteries will be ok if you keep the volume at a moderate level most of the time. But if you play a 5kw system at full blast, a 200 amp alternator ain't gonna cut it.
Abbotsford, BC
Post Number: 48
word... thanks for the info.... so a 200amp and 2 2400's will be ok... just ok? aint nobody make a 300 amp for a 2004 toyota tacoma...
Username: Nd4spd18
Southeast PA
Post Number: 2352
For normal listening, probably. But like GlassWolf said, you really need 2 of those alts to play that system at full volume.
Username: Clouduz
Post Number: 213
just don't play at full volume and you should be ok
Username: Th3pwn3r
Post Number:...
Post Number: 2566
Where's Matt A.K.A Waterboy when he should read and learn something?
Username: Killswitchjd
Post Number: 558
you could probably not run the system half the time and charge the batteries then bump it to full volume for 30 seconds or something, just to see what it will do with more power and see if its worth it to you for daily use.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Amp/alt/batts [ « Previous ] [ Next » ]
