Thread: No sound Alpine IVA-D100 |
New member Username: Bignbeefy
Las Vegas,
Nv
Us
Post Number: 1 Registered: May-07
| Posted on Saturday, May 12, 2007 - 02:56 pm: |
Hi Guys i installed a IVA-D100 now my issue besides space is I only get audio on radio i put a cd or dvd and get no sound, anyone have this problem and even better a solution to this matter, thnx i really apreciate your help BNB |
Bronze Member Username: Kpa2727
Post Number: 16 Registered: May-07
| Posted on Saturday, May 12, 2007 - 08:12 pm: |
i've never had a dvd system but by looking at other forums models blah blah, check your inputs see if u mis dirreected your dvd audio inputs and hooked them up wrong or check your setting fro audio you might still be ina stereo mode even though your dvds on. i'll bring up a manual pdf and give u more info . |
Post Number: 17 Registered: May-07
| Posted on Saturday, May 12, 2007 - 08:21 pm: |
if u read on page 16 of your manual it saysthat depending on what you have hooked up it will change ur display and how audio functions and is used. basicllly it statesif u have a dvd changer it has to be selected now for audio this dosen't make complete sense seeing as how you said the dvd plays which if that source isn't selected the dvd should play by my assumption. your best bet go through your wiring and manual. i'm sorry i can't help more. |
New member Username: Bzjeep
Utah
Post Number: 5 Registered: May-07
| Posted on Sunday, May 13, 2007 - 03:13 am: |
What vehicle was this installed into and did it have a factor amp with the audio system? |
