Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Alpine type r's autotek amp
Author Thread: Alpine type r's autotek amp
Username: Pbplayer05
im buying two type r 12inch dvc 4ohm subs and need and amp for them i was thinking about the autotek 1400.1d amp wired at one ohm anyone have suggestions please help
Username: Johnfiac
A-ToWn, 152-153db Da...
My wangers b...
Post Number: 2719
Did you already order the subs?
no i havent bought them yet
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4584
i would buy autotek mm1000.1 if you want to stick with the brand. If not, then grab memphis prd 1000.1
so the 1000 watt should be good enough for the two subs? also im doing this with 4 gauge and a 1/2 farad cap do i need to upgrade or would this setup still work
Username: Joebruce
15 Inch Wang...
Post Number: 860
4 guage wire is fine but i wouldnt use the cap. Whats your budget for an amp?
Username: Nd4spd18
Southeast PA
Post Number: 2291
4 gauge is just barely enough, but should work..... and caps are useless, don't bother with that.
Username: J_c_wheeler8
Columbus, IN
United States
Post Number: 476
What are caps?
Username: Imalik
SD2.5ED9.1=Boom, New Jersey
Audioque...N...
Post Number: 285
Capacitors.http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2686
Columbus, IN
United States
Post Number: 482
why are capacitors useless? Don't they hold extra juice so your battery doesnt die?
Username: Nd4spd18
Southeast PA
Post Number: 2296
lol no. A capacitor holds a VERY small amount of energy. They are marketed to noobs who think it will stop their lights from dimming (voltage drop) when they in fact do nothing to help your electrical system.
i was thinking between 200 and 275 but lower would be better
so if not the caps will this take to much energy from my cars charging system?
otherwise does anyone else have an amp that would do better for that price range
Post Number: 7
otherwise does anyone have a better amp suggestion for the price range
Username: Shade
Moxee, Wa
U.S.
Post Number: 248
i thought i heard someone say they found a kx1200.1 for around that price.
Username: Johnfiac
My wangers b...
Post Number: 2745
my friend sold a zx1200.1 last year for 200$ it was in perfect condition and never even had the gain turned up to see the full output... i was so pissed when i found out i missed that deal... :-(
Post Number: 9
so what do you think would be the best amp for a setup like that? autotek kicker jbl hifonics or are there any better ones
Columbus, IN
United States
Post Number: 484
It was me who just got a kx1200.1 for around $250.00 I love it!
Post Number: 10
what do u have it pushing though cuz i want enough power for these subs without frying my charging system
Username: Jkidder
Spring hill, Florida
Usa
Post Number: 562
i didnt know kicker ever mader a zx1200?
Username: Nd4spd18
Southeast PA
Post Number: 2319
^^^ they don't
Post Number: 11
would a 15" type r be better than buying two twelves
Username: •cam•
Post Number: 198
lower maybe, louder no.
Post Number: 12
so like my first question does anyone know what the best set up for an ap i could get atthat price be?
Username: Shade
Moxee, Wa
U.S.
Post Number: 253
maybe a hifonics bxi1606d or look around for a kx1200.1 used or refurb. basically you'll want no less then 1000watts RMS for those subs at 1ohm.
ebay is your friend.
Columbus, IN
United States
Post Number: 495
http://cgi.ebay.com/ebaymotors/Kicker-KX1200-1-car-audio-amp-class-d-1200-watts- WOW_W0QQcmdZViewItemQQcategoryZ38638QQihZ014QQitemZ330117505420QQrdZ1QQsspagenam eZWDVW
http://cgi.ebay.com/KICKER-KX1200-1-Class-D-Mono-Car-Audio-Amplifier-MINT_W0QQit emZ290114437145QQihZ019QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/KICKER-KX1200-1-CAR-AUDIO-AMPLIFIER_W0QQitemZ330118045954QQi hZ014QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/KICKER-KX1200-1-ZX1500-1-CAR-AUDIO-SUB-AMP-AMPLIFIER_W0QQite mZ140115915797QQihZ004QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
ALL Kx1200.1's at great prices.
Home > Message Board > Car Audio > Amplifiers > Archive through May 15, 2007 > Alpine type r's autotek amp [ « Previous ] [ Next » ]
